Hello Guest it is October 23, 2026, 06:16:57 PM
Author Topic: Default Jog Speed/Rate Value?  (Read 5350 times)
« on: September 17, 2020, 03:31:54 PM »
I'm using the Avid CNC setup on one of their Standard machines.
I'd like to have the Jog rate set at around 35 or so as my default.  I have been searching all around trying to find how that is set.  I saw on the screen close script, there is a save to the Machine.ini file. But for some reason, that doesn't always save the current setting.  I manually changed the value in the ini file and that works, but if I change the rate on the screen, then close, it doesn't get saved.  Any ideas?  Thanks!
Tony
