Hello Guest it is November 22, 2026, 06:15:35 PM
Author Topic: Strange Z Axis problem only with MeshCAM generated G code  (Read 9281 times)
« on: September 14, 2020, 07:26:53 PM »
I'm finding that 3D roughing code generated by MeshCAM clips the edge of the stock as if the Z axis starts moving too soon. It only occurs in 3D roughing. Mach3 has been working flawlessly for the past 3 months doing 2D and 2 1/2D routing. This is the first time I've used 3D. The errors seem to occur when a single line contains a X and Z move. I've tried turning off Constant Velocity, but is has not changed anything. I've tried slowing down the Z axis, which makes it worse (bigger bite on the edge of the stock) I've tried slowing down the X and Y axis, no joy. I'm hoping that someone else has already solved this before.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Strange Z Axis problem only with MeshCAM generated G code
« Reply #1 on: September 15, 2020, 09:07:41 AM »
Are you using a ball nosed cutter?
« Reply #2 on: September 15, 2020, 12:37:21 PM »
No, not a ball nose end mill. The tools used in all passes are straight 1/4" end mills.
  •  2,785 2,785
« Reply #3 on: September 15, 2020, 04:02:35 PM »
Most 3d work needs a ball nose cutter, I would check your CAM software because it sounds as if its expecting a ball end.
« Reply #4 on: September 16, 2020, 07:46:44 AM »
I agree, that is exactly what it seems like. But I also wanted to make sure that I was not doing something wrong with the Mach3 setup
Using something other then a bull nose tool for 3D machining might seem different but if you can select a straight end mill as your 3D tool I'd expect the CAM software to be able to compensate for the tool geometry.
