Hello Guest it is November 22, 2026, 05:56:52 PM
Author Topic: My energized motors sound like a copper pipe in the wall running water  (Read 7262 times)
I changed out my contol system from a Novsunun with T6600 stepper drivers to a ESS Smootherstepper and a G540 to run the stepper motors.
When I turn on the power I hear the steppers energizing but they do sound like a copper pipe that is in the wall with water running through it.
Is this normal?  Should I have concerns?   Now, the motors are not turning, they just have power to them.
  •  9,378 9,378
Re: My energized motors sound like a copper pipe in the wall running water
« Reply #1 on: September 14, 2020, 09:05:21 AM »
If you post your .xml file then we can check your Mach3 settings. You will have to rename the file to a unique name for the forum to allow it to be attached - elder.xml would be good.
