Hello Guest it is October 21, 2026, 02:02:39 PM
Author Topic: Z axis inconsistent movement  (Read 31530 times)
« on: September 03, 2020, 05:07:27 PM »
My Z axis is creeping upward during the program run.
I have run the following gcode with a repeatable error.
The original location of Z 0
Code Run
Z10
Z0
Will give me a Z offset of +0.002mm each time I run it. But Mach 3 display is Z0.
Original location of Z 0
Code Run
Z5
Z10
Z0
Will give me a Z0 each time I run it and Mach 3 display is also Z0.
Basically start at Z0 with Z10 Z0 will give me an error in Z but Z5 Z10 Z0 will be correct.
Does anybody know how to fix this?
  •  9,374 9,374
Re: Z axis inconsistent movement
« Reply #1 on: September 03, 2020, 11:57:25 PM »
Try reducing your Z axis Acceleration and Velocity (in motor tuning) by 50% and apply the changes. Does the problem still occur ?
« Reply #2 on: September 04, 2020, 12:01:01 AM »
Yes, have tried that. Even to 10% it still has that. The odd thing is if I do step up or step down it does not have any error. Z5 Z10 Z15 Z20 Z0 will give me no error. Z20 Z0 will give me a consistent error each time I run it.
  •  9,374 9,374
« Reply #3 on: September 04, 2020, 12:27:28 AM »
What are the Acceleration and Velocity figures you are currently using ?
« Reply #4 on: September 06, 2020, 04:01:16 PM »
Hi
My acceleration is 150mm's and velocity is 2800mm's
thanks
« Reply #5 on: September 07, 2020, 06:31:22 AM »
0.002mm  = 0.000079"
What is your theoretical and actual resolution for the Z axis ?
How are you measuring that error?
How is that axis driven and are the axis components of dimensional quality ?
Just a few practical considerations.
« Reply #6 on: September 07, 2020, 03:32:23 PM »
the 0.002 is an averaged number. as I did repeated z5 z0 10 times it becomes 0.02. I have also done z5 z10 z0 10 times it has no error.
thanks
Offline ZASto
  •  434 434
« Reply #7 on: September 08, 2020, 03:39:23 AM »
If you repeat your "problematic" sequence 100 times, what is the result?
How do you measure micrometer difference? I guess that the resolution as well as repeatability of your machine is much worse than 2um.
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
« Reply #8 on: September 08, 2020, 04:33:57 AM »
my machine have about 0.01 resolution.
I'm measuring using a dial indicator. I fixed a dial indicator to the bed with the indicator pin to the bottom of the spindle shell. marked that as Z0.
I can see a noticeable change every time I run Z10 Z0, which raise Z to 10 them back to 0.  it has a consistent change of the Z hight each time I run the code. It averages out about +0.002mm. I have set up the code to run 100 times it had about +0.19mm in Z hight.
With the same setup, the code Z5 Z10 Z0, which raise Z to 5 then raise to 10 them back to 0. it has no noticeable change of the Z hight regardless now many time I Run the code. I have run the code up to 200 times it had no change to the Z hight.
I have also run the code Z5 Z10 Z5 Z0 , which raise Z to 5 then raise to 10 them back to 5 then back to 0. it also has no noticeable change of the Z hight hight regardless now many time I Run the code.
  •  9,374 9,374
« Reply #9 on: September 08, 2020, 05:21:26 AM »
Perhaps one more test you could do is zero your Z axis to a gauge block (any solid block would do) – carefully slide out the block – run your test 100 times – slide in the block – measure the gap with feeler.
This would verify the integrity of your dial indicator.
