Hello Guest it is October 10, 2026, 12:43:23 PM
Author Topic: ".txt" files and switching from Mach 3 to Mach 4  (Read 7370 times)
« on: September 02, 2020, 05:42:14 PM »
I use V-Carve Pro and it has the option to create "Mach 2/3 .txt" files for G-code.  But it doesn't have the option for Mach 4 .txt files.
My question is this: If I switch to Mach 4 should those "Mach 2/3.txt" generated G-codes still run on my machine that now has Mach 4 operating it instead of Mach 3?
  •  9,374 9,374
Re: ".txt" files and switching from Mach 3 to Mach 4
« Reply #1 on: September 03, 2020, 12:02:29 AM »
Yes.
The Mach 2/3 .txt files will run on Mach 4.
