Hello Guest it is November 22, 2026, 09:47:13 AM
Author Topic: Sony laptop  (Read 20653 times)
Ron
Sony laptop
« on: April 05, 2006, 04:37:53 PM »
I am getting into the cnc router - mach 3...Can I use a sony laptop to run the machine...thanks...any other computer suggestions would be appreciated.....
Re: Sony laptop
« Reply #1 on: April 05, 2006, 05:13:40 PM »
Laptops are not the best to run Mach on... Some work and some don't... Anyone have laptops that run out there?
www.newfangledsolutions.com
www.machsupport.com
Ron
Re: Sony laptop
« Reply #2 on: April 05, 2006, 07:10:30 PM »
Thanks....Is 512 MB enough to run Bobcat nc router..Thanks
Re: Sony laptop
« Reply #3 on: April 06, 2006, 07:19:22 AM »
I'm running on a HP N3310 500MHZ laptop with WinXP. Has 196meg of mem, 4.3G hard drive & Wifi. Have many services disabled. Seems to drive Mach3 just fine
Re: Sony laptop
« Reply #4 on: April 07, 2006, 12:30:13 PM »
I just installed Mach3 on a new HP nc6120 running Windows XP Professional.  After a hint from Art that I should try the optimisation guide I got things running.  I selected the HP nc6120 because it is one of the only new notebooks on the market that still has a parallel port.  Everything else seems to be going USB.
Hope this helps,
Ed
Re: Sony laptop
« Reply #5 on: April 07, 2006, 03:27:52 PM »
I am running Mach3 on a "Toshiba satellite" laptop 1.7Gh processor, 512Mb RAM, Windows XP, using single parallel port output/input via a CNC4PC parallel breakout board.
No Antivirus software running.
Seems OK so far.
Re: Sony laptop
« Reply #6 on: April 08, 2006, 07:45:36 PM »
Is anti virus software an issue?  I would imagine it could be a problem.
