Hello
Guest
it is
November 13, 2026, 07:09:48 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Question on OD Arc 3 In turn wizards
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Question on OD Arc 3 In turn wizards (Read 10346 times)
derek
200
on:
October 02, 2007, 05:56:17 AM »
How does the wizard work without knowing the profile or dimensions of the cutting tool?
Derek
Logged
Carnoustie, Scotland
Re: Question on OD Arc 3 In turn wizards
Reply #1 on:
October 04, 2007, 02:01:06 PM »
Never tried the wizard yet as my Lathe is just in the final stages of the retrofit but I presume you are meant to use a tool with similar shape as is in the wizard.
Logged
DAlgie
314
Reply #2 on:
October 07, 2007, 02:00:08 PM »
None of the wizard profiles have reentrant cycles in them so it really doesen't matter at all. The main thing is the tool tip radius, which it will use.
DaveA.
Logged
Print
Pages:
1
Go Up
« previous
next »
