Hello Guest it is November 27, 2026, 12:07:20 PM
Author Topic: Mach3 Turn-ATC M6 Error "M6Start unexpected ERROR TRAP!"  (Read 18853 times)
« on: August 18, 2020, 02:31:36 PM »
Group,
I am getting the following error:  Mach3 Turn-ATC M6 Error "M6Start unexpected ERROR TRAP!"
Any ideas on what might be causing this?
The ATC works most of the time.. then it gets this error.... then it stops working  via M6 command.
I can move the turret with a  G1 A120 F6000 (For example) from the MDI....
Any ideas are appreciated.
Joe
Re: Mach3 Turn-ATC M6 Error "M6Start unexpected ERROR TRAP!"
« Reply #1 on: August 18, 2020, 05:35:49 PM »
Check out the screen shot.
- The Title on it is:   "Control RESET, Tool change Aborted"
- It's in the form of a MsgBox... with an OK.. wonder where this can be being called?   Mach?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: August 20, 2020, 06:45:42 PM »
You need to look at the M6Start macro
Offline TPS
  •  2,627 2,627
« Reply #3 on: August 22, 2020, 05:09:37 AM »
post your M6Start macro to have a look.
