Hello Guest it is October 23, 2026, 04:12:29 PM
Author Topic: 3D touch-probe with large offset to spindel  (Read 6677 times)
« on: August 17, 2020, 05:42:33 AM »
Hello all,
I'm new to this forum and hope that you could help me with my problem.
I have converted a manual mill over the last months to cnc. For the controller
I'm using a pokeys57cnc with mach4 hobby.
Now I have the following problem:
I build a retractable 3D touch probe which is permanently mounted to the mill
with a large offset (round about 85mm in x) to the spindle. I can't find a way
to calibrate the touch probe. Is it possible to set the Position of the precision bore to zero
but calibrate at the current position? This way i could zero my spindle und move the
touch-probe to the bore and run the calibration routine.
I hope you could help me with my problem.
Best regards,
KDRedSmith
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: 3D touch-probe with large offset to spindel
« Reply #1 on: August 17, 2020, 08:46:57 AM »
It is normal to calibrate the probe at 0,0 once that is done the exact offset from the probe to the spindle c/l can be measured using a clock and the offset stored in some DRO's
Then when setting a fixture datum the probes found position can be offset with a G10 command to correct the position ether in the probe macros or with a MDI/button command on screen.
« Reply #2 on: September 17, 2020, 12:37:05 PM »
sorry for the late reply. Thanks for your answer. I measured the offset between my spindle and the 3D touch probe with a clock as you suggested. I then wrote a custom button script which moves my spindle the specific amounts and re-zeros, this works fine.
But now i have an other Problem i wanted to reset my Probe offset to X0 and Y0 but with the Calibration routine I always get a wrong offset no matter how accurate it is. The only thing I need calibrated from the software is the Radius of my touch probe.
Best regards,
KDRedSmith
  •  2,785 2,785
« Reply #3 on: September 17, 2020, 08:47:52 PM »
Have 2 buttons one that allows for the probe/spindle offset and one that is probe centre line only.  You could also have a spindle c/l only button too.
