Hello Guest it is October 22, 2026, 05:55:22 PM
Author Topic: Goto Work button and cnc continues to cycle run  (Read 4916 times)
« on: August 16, 2020, 02:13:10 PM »
I am new to the forum. I have an issue that just started and I dont know how or where to correct. I have restored from an older backup before the issues but that did not help.
When I press the Goto work zero the cnc does go to work zero but does not release and the cycle time continues to run. I have to manually press stop. If I run a gcode it does the same thing I have to press stop and then start to get the cnc to continue to run the code. Really annoying. If anyone can point me to where I should look I would really appreciate any help.
Thank you
