Hello Guest it is November 16, 2026, 10:07:17 PM
Author Topic: Help need with a USB BSMCEO4U-PP Bitsensor  (Read 10740 times)
« on: August 12, 2020, 04:52:12 AM »
Hi all, I recently purchased a ebay 6040 CNCEST USB machine. I have tried to add a touch plate for the z axis however when i hook it up to in4 and ground and set the port to 3 and pin to 4 in mach 3 i do not get the led flash on digitize. Could this be down to a faulty board? Everthing else works its just this one issue im having. Please let me know if you have any suggestions.
I have also attached images of our cnc6040 router, touch plate and board
Many thanks, Graham
Offline MN300
  •  306 306
Re: Help need with a USB BSMCEO4U-PP Bitsensor
« Reply #1 on: August 12, 2020, 07:45:54 AM »
Maybe your breakout board requires a pull up resistor. It should measure 5 volts with nothing connected. What is the number of your board?
Offline MN300
  •  306 306
« Reply #2 on: August 12, 2020, 07:58:59 AM »
Disregard my earlier post, I had assumed BSMCEO4U-PP was the number of the touch plate.
https://www.machsupport.com/forum/index.php?topic=41002.0
