Hello Guest it is October 12, 2026, 12:51:46 PM
Author Topic: Boko CNC mill - new hybrid stepper motors, Mach3 retrofit  (Read 48802 times)
« on: August 12, 2020, 01:07:30 AM »
This BOKO CNC mill is for sale in Liverpool, UK. Bed travel is 1000x600 mm. ISO40 spindle. Running on new hybrid stepper motors. Retrofit is unfinished but all the hardware needed is included with the machine. It is running on two parallel ports with Chinese breakout boards. The main panel board needs fitting in a cabinet so does the PC and display. Z axis motor needs fitting in the machine. Drives are all installed on the panel board. Spindle is controlled through inverter by a POT. I was carrying out the retrofit when the pandemic hit us and I had to leave. Mechanically the machine is in very good shape.
Zafar
Re: Boko CNC mill - new hybrid stepper motors, Mach3 retrofit
« Reply #1 on: January 23, 2021, 01:29:34 PM »
id like to get more info on this item. i am looking for 2 mills
