Hello Guest it is October 22, 2026, 11:14:11 PM
Author Topic: Mach 4 and odoo database?  (Read 5462 times)
« on: August 11, 2020, 06:23:10 PM »
We are building cnc fence for chop saw. We have a odoo database and in db there is all aluminium profile lenghts needed to cut. Is there any way to send mm lenghts from odoo to mach4. Like browser with odoo open and there is "send to mach" button and mach get MDI value and then GO TO MDI BUTTON.
Re: Mach 4 and odoo database?
« Reply #1 on: August 11, 2020, 10:05:58 PM »
i think its easier bulid some pp that will take the data from yours database ,pp will create nc file ,then can by api open the mach load the nc file and even run it (if you want without even need see mach interface)
mach have large api options to run from .net
