Hello Guest it is October 22, 2026, 09:10:34 PM
Author Topic: Won't generate tool paths  (Read 6320 times)
« on: August 01, 2020, 06:20:21 PM »
I am trying to open an g code in Mach4 hobby and it always just sits at "tool path progress" at 0% and never loads. If you cancel and hit Regen tool path , same thing.
I've tried the sample codes that come with Mach4 and always the same result. Somebody please help me!!
Re: Won't generate tool paths
« Reply #1 on: August 03, 2020, 10:37:14 AM »
Well, I don't know what I did, but it seems to work for now. I even ran some code. Fingers crossed.
Offline OregonMike
  •  10 10
  • MRM
« Reply #2 on: March 25, 2023, 12:43:35 PM »
I know the thread is old, but I started having this problem with every new gcode file I created after about March 10.  All my pre-March files load into Mach-4 Hobby just fine.   I use Fusion360 to make the g-code.
Does anyone know if something changed in Fusion360?  If so, do I fix the problem by changing a setting in Fusion or in Mach4.  My Mach4 version is about 2-3 years old.
Thanks for any help.
