Hello Guest it is November 28, 2026, 01:41:56 AM
Author Topic: bad allocation error  (Read 8690 times)
« on: July 24, 2020, 01:19:57 AM »
i try load big nc file
after the file finish to load ,i got this error
never see
is some one matt such error?
Re: bad allocation error
« Reply #1 on: July 24, 2020, 01:41:48 AM »
i try send here the file but its 25Mb cant send here
when i cut to half its let mach load it
but freinds its very confused because all chines cheap system can load such program only our cant??
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: July 24, 2020, 03:51:59 PM »
What version are you using
« Reply #3 on: July 26, 2020, 03:52:44 AM »
4.2.0.4300
« Reply #4 on: July 27, 2020, 08:04:30 AM »
25MB! How big is this thing! We can make a mode where it works but you will not have the toolpath and so on. You need some good hardware to make that happen.
www.newfangledsolutions.com
www.machsupport.com
« Reply #5 on: August 03, 2020, 12:36:57 AM »
its not such big(as you can see at atach i can use ony half part ,if i not cut the file its cant load)
what do i need to do to run this complete file?
