Hello Guest it is November 27, 2026, 07:32:49 PM
Author Topic: Celtic Cross from cherry wood  (Read 29800 times)
« on: September 29, 2007, 12:22:24 PM »
Greetings. Just want to show the celtic cross I made using AutoCAD LT and LazyCAM. The cross was cut out and pocketed by LazyCAM. That left me with only the fun part: cutting the knotwork. What used to take me a couple of days, now takes me a couple of hours.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Celtic Cross from cherry wood
« Reply #1 on: September 29, 2007, 05:17:56 PM »
Nice, very nice.
Do you mean the knot work was done by hand.
Graham.
« Reply #2 on: September 29, 2007, 06:31:38 PM »
Sort of... What I made with the CNC kind of looked like a waffle. I'll post a LazyCAM screen shot so you can see. I used a 0.0512" single flute carbide cutter in a dremel. The CNC did all the pocketing down to 1/8"and outlined everything. The pockets in the circle were entirely done by the CNC. I used to have to do that by hand and it is very time consuming and difficult to do consistently. The only thing left for me to do was carve along the pattern to make some lines go under and some lines go over. I could have pushed the CNC to do that too... but that's the fun part for me. It would need to be full 3-D and I'd have to draw it in something like Rhino 3-D and cut it in multiple raster passes with something like FreeMill. That would take more time and the straight lines wouldn't be as straight unless the number of passes was very high. Also, with something like this, if it is done by a machine it just looks too perfect.  :)
« Last Edit: September 29, 2007, 06:40:55 PM by ergoman »
« Reply #3 on: September 29, 2007, 07:48:53 PM »
Good Job!!!!!!!!!!!!!!
Offline docltf
  •  354 354
« Reply #4 on: October 01, 2007, 09:19:31 PM »
looks good ,what did you do for the finish.
bill
ynneb
« Reply #5 on: October 02, 2007, 01:32:18 AM »
Brilliant
« Reply #6 on: October 02, 2007, 06:50:57 AM »
For the finish, I just used a couple of coats of clear polyureathane - sometimes I'll use Tung oil... but that takes longer. Thanks much for the encouragement, gentlemen!
ynneb
« Reply #7 on: October 02, 2007, 05:57:56 PM »
I want one. Not that I'm a religious artifacts type of guy.
But it looks good.
« Reply #8 on: October 03, 2007, 06:23:46 AM »
Funny you should mention it... I've just sold that cross on e-bay for $41.00. I'm trying to fund this expensive hobby of CNC. :)
Thanks for the compliments, gentlemen! We've got ourselves an excellent hobby here! BTW here is a picture of what the CNC gives me.
« Last Edit: October 14, 2007, 08:19:59 PM by ergoman »
« Reply #9 on: October 28, 2007, 06:46:52 PM »
Brilliant design !! What software did you you use for the design of the cross?
