Hello Guest it is November 19, 2026, 06:04:45 AM
Author Topic: Randomly stopping on G4 P0.1 Command  (Read 52652 times)
Re: Randomly stopping on G4 P0.1 Command
« Reply #10 on: July 21, 2020, 07:55:10 PM »
So I figured out my problem and wanted to post the solution for anyone who runs into similar problems.
When downloading the support files for TMC 3in1 you need to install the m2020 macro from warp 9’s page. MAKE SURE THE OTHER M2020 IS DELETED!!!!!!
This was a very large pain in my rear that I caused myself by following the steps to fast. It also took way to long to figure out.
Hopefully my mistakes help someone in the future. Thank you all for you assistance
  •  9,378 9,378
« Reply #11 on: July 22, 2020, 03:45:13 AM »
Many thanks for reporting back with the solution Cbert10, I am sure this will help others in the future.
« Reply #12 on: November 12, 2020, 04:07:06 PM »
I’m have the same issue and this fix didn’t work. Was there anything else you did? It only happens after probe
« Reply #13 on: November 24, 2020, 09:22:03 PM »
That seems to be the only thing that I did to fix it. It has been running fairly good since then, with no more of the above issues.
