Hello Guest it is November 29, 2026, 01:27:41 PM
Author Topic: Mach 4 says ESS not connected  (Read 13596 times)
« on: July 13, 2020, 12:26:27 PM »
Hi there,
Currently I'm trying to config my ESS and Mach 4, but when I hit the config and go to the ESS plugin, it keeps saying that "it does not appear that you are connected to the ESS board." I have checked with the SCU software from Warp9, and it is receiving successful pings, and the board is receiving power just fine. I have also switched out the Ethernet adapter cable, and its the same result. The upper green light LED on the ESS is also just doing 2 short blinks (nothing else).
I am not sure what else to do here to fix this, anyone have any suggestions?
Thanks in advance,
Starting_Anew
Offline Stuart
  •  311 311
Re: Mach 4 says ESS not connected
« Reply #1 on: July 13, 2020, 12:39:54 PM »
Have you selected the ESS in mach4 select plugins
« Reply #2 on: July 13, 2020, 12:52:11 PM »
Yeah, its all checked.
« Reply #3 on: July 13, 2020, 03:29:53 PM »
you need to go to the Warp9 forum and request Andy's help.
I had a bit of a battle trying to get the ESS to connect initially, my own fault as it transpired. In particular I had
messed up the firewwall settings.
The SCU is good for 90% of occasions, the other 10% require some in depth diagnosis even if the eventual solution is fairly
simple. Take advantage of Andy's expertise.
