Hello Guest it is October 20, 2026, 03:00:43 PM
Author Topic: Offset dont add up  (Read 10359 times)
Offset dont add up
« on: July 13, 2020, 05:26:49 AM »
Im sorry to have to post this again but I got a super clever answer from one member and that seems to have frightened other off.
I just need to know can this be done with offsets
I need to accurately drill holes in PCB'. I fetted a USB microscope which gets the 0.2mm crosshairs etched on the PCB fill screen.
At this point I zero x and y in G54.
The difference between the crosshairs and actual workpiece zero and the camera crosshairs and the spindle adds up to an offset of -88mm in x and -63mm in y.
So if I simply move the spindle -88 and -63 then rezero in G54 the program performs fine and all the holes drill in place.
But it is a nuisance doing this every time.
I thought if I put the offsets into G55 manually I would be able to bring this offset in after setting x and y to zero in G54, but when I zero the machine coordinates the G54 offsets alter to numbers that make no sence. There seems to be a legacy value from the machines move before zeroing.
If I the switch to G55 the offset is way out and it misses the board completely.
How can moving the head work and changing to G55 not.
How can I either in zeroing the machine coordinates also make the G54 zero so that when I switch to the G55 the new zeros is at the -88 and -63 position.
It seems like whackamole as soon as I alter one offset it moves all the others and the -88 and -66 become corrupted.
Am I just missing the point .
All I want to do is zero in the crosshair. then tell it that really zeros is -88 and -63 from where the spindle is sitting.
Thanks in advance if any of you can help.
I feel like I am in limbo.
Nothing seems to add up.
Best regards
Forbin One
  •  9,374 9,374
Re: Offset dont add up
« Reply #1 on: July 13, 2020, 06:00:29 AM »
Perhaps take a look at the method I use for Tool Position Setting;  http://www.tweakie.byethost10.com/17.htm
(Use the Screen Editor to add a VB button to your screen that contains the offset between your crosshair and cutter. Clicking the on-screen button moves the cutter by that amount).
« Reply #2 on: July 13, 2020, 08:23:06 AM »
Very Much appreciate you help, been to the page and it is obvious to me that if I am going to become the master like yourself I need to learn to integrate VB scripts into my Mach3. Thanks again. Working my way through your pages after this.
Offline ZASto
  •  434 434
« Reply #3 on: July 13, 2020, 03:34:34 PM »
Tweakie's laser can be substituted with small endoscopic camera, as I wrote you in other thread.
You will have to edit your screen set adding 2 DROs (for camera offset), two buttons for turning tha camera on and for setting XY zero with measured offsets, contained in extra DROs.
You can find Big-Tex blue toolsetter screenset and modify it, as I did.
My personality is who I am.
« Reply #4 on: July 13, 2020, 04:26:11 PM »
I will add my own reply and thank Zastro and Tweakie but I have worked out an even simplet soluition.
I simply park the crosshairs of the usb microscope over the Crosshairs on the pcb etch and on the main screen, touch the x dro and overide the value with the offset and the same with Y. It just accepts its where i want it to be and cracks on.
