Hello Guest it is October 22, 2026, 05:56:25 PM
Author Topic: Screenset gone missing  (Read 9047 times)
« on: July 06, 2020, 08:37:09 AM »
I am installing Mach4/ESS  as a retrofit control on an older machine.
While in the process of assigning ports and pins in separate sessions, on the last boot of Mach4 the msg;
" screens\wxmach.set does not exist" popped up when the active profile was chosen.
This has slowed progress a bit.  Does anyone have suggestions or remedies?
Offline thosj
  •  542 542
Re: Screenset gone missing
« Reply #1 on: July 07, 2020, 09:45:39 AM »
I guess, look in Mach4Hobby/Screens, and if that file is not there, that would explain that. Your profile is looking for that screen and it isn't there. I'm not sure modern versions of Mach4 install that screen, so if you've upgraded Mach4 but an old profile is looking for that screen, there you go.
One thing to remember, if you're going to edit a "stock" Mach4 screen, rename it before editing or it will be over written on a new install.
Tom
