Hello Guest it is November 13, 2026, 12:03:30 PM
Author Topic: Can you run cnc plasma cutter using Mach3 with a 24v dc Z axis motor?  (Read 8530 times)
Hello  :) ,
I am a beginner using Mach3 and currently building a DIY CNC plasma controller and I was thinking of using stepper motors for the x and y axis and I have bought a 24v dc z axis motor to move up and down with manual switches.
Can I use this 24V motor directly onto my mach3 compatible board (using relays)? Or do I need to control it using a stepper motor? If I can what settings do I need to modify on Mach3 to set the correct port of the z axis to be the one of the 24V?
Thank you
Mach3 is a step/direction controller, and that is what makes it ideal fo stepper motors  or servos with
ste/direction input drives.
A 24VDC motor requires an varying voltage, both amplitude and polarity, to control it. Mach3 doe not do that,
you need a drive that can and such drives require a motor position feedback device, an encoder or resolver, to
control the motor position. In short the simple and cheap 24VDC motor beomes a lot more complex and expensive
when it is required to be position controllable. A stepper is a cheaper and easier solution.
Thank you for your reply. That is what I will do then I will just replace the 24v motor with a stepper motor and keep the same up/down configuration which I bought
