Hello
Guest
it is
September 30, 2026, 02:58:44 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
MACH3 stalls on M3 command
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MACH3 stalls on M3 command (Read 7537 times)
Soorena123
2
on:
June 25, 2020, 01:54:32 PM »
When I try to run my code Mach3 stops and doesn't move past S12000M3 command. I've tried various post processors and its always this section it gets stuck on. The simulation works no problem. Weird thing is that S12000M3 actually works in MDI and when the GCode reaches it the spindle actually turns on and goes at 12000 speed. It just won't proceed with the rest of the program.
Has anyone else had this problem?
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: MACH3 stalls on M3 command
Reply #1 on:
June 25, 2020, 07:19:32 PM »
Only time I have seen this is when Mach is waiting for the spindle to reach speed, so make sure feed back is working or if you do not have feedback turn off closed loop and feedback.
Or it could be none of this.
Logged
Print
Pages:
1
Go Up
« previous
next »
