Hello
Guest
it is
November 13, 2026, 10:47:15 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
PDB issue Mach 3 ATC
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: PDB issue Mach 3 ATC (Read 13562 times)
StuartW
24
on:
June 19, 2020, 06:29:31 AM »
Hi there I have attached 1 Macros, newbie here I am trying to work out why the pdb wont close and gives me the error pdb failed (tool not secure). when it actually has opened and closed correctly.All help appreciated. Stuart
Logged
StuartW
24
Re: PDB issue Mach 3 ATC
Reply #1 on:
June 19, 2020, 06:35:50 AM »
This is thr M6Start file if needed, I have been trying for many hours to work this out and am lost. regards Stuart
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Reply #2 on:
June 19, 2020, 07:06:31 AM »
Are you running Mach3 or Mach4 because you have files from both here M6Start.mcc is compiled Mach4 Lua and M131.m1s is Visual Basic from Mach3
Logged
StuartW
24
Reply #3 on:
June 19, 2020, 07:11:24 AM »
I am running Mach3 only. regards Stuart
Logged
Graham Waterworth
2,785
Reply #4 on:
June 19, 2020, 07:20:40 AM »
So the M6Start.mcc is not a Mach3 file, so we need your M6Start.m1s file from your working profile.
Do you have a tool change page on your screen, if so post a picture of that too.
Last Edit: June 19, 2020, 07:26:25 AM by Graham Waterworth
Logged
StuartW
24
Reply #5 on:
June 19, 2020, 07:26:09 AM »
I have attached I had to change the name as it would not let me upload it as start.M1s file regards Stuart
Logged
StuartW
24
Reply #6 on:
June 19, 2020, 07:43:02 AM »
Is this the .set file you mean?
Logged
StuartW
24
Reply #7 on:
June 20, 2020, 06:31:17 AM »
Can anyone help me with this problem? All help appreciated regards Stuart
Logged
Graham Waterworth
2,785
Reply #8 on:
June 20, 2020, 06:04:26 PM »
There is far more to this than just a screen set, there are images and macros too.
Logged
StuartW
24
Reply #9 on:
June 20, 2020, 06:33:23 PM »
Hi Graham I can send you the whole mach3 folder privately which would make it far easier to investigate if you like? regards Stuart
Logged
Print
Pages:
1
Go Up
« previous
next »
