Hello Guest it is November 13, 2026, 12:44:31 PM
Author Topic: Mach3 gcode parameters  (Read 8782 times)
« on: June 17, 2020, 07:10:54 AM »
Hallo
We had an old machine with Siemens 810 control. So we retrofitted it and using mach3
Im working on translating the old programs into mach3.
Most Parameters and Unary/operators are in mach3 gcode manual, but can’t find code for programing “jump” and “if” functions in mach3.
Thought "GoTO N20" should work, but doesn’t recognize the command "GoTo"
Siemens 810 equivalent  "@100 K10"
Subprograms and parameter calculation works like a charm, but the jumps/if doesn’t.
Anyone able to help?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach3 gcode parameters
« Reply #1 on: June 17, 2020, 08:03:06 AM »
Mach3 has no loops jumps or ifs, Mach4 has full Macro support
« Last Edit: June 18, 2020, 09:12:36 PM by Graham Waterworth »
« Reply #2 on: June 17, 2020, 08:32:06 AM »
 :-[ ok, thanks
« Reply #3 on: June 17, 2020, 08:11:52 PM »
I belive that ONLY Mach4 "Industrial" has full macroB support ??
Just  a thought , (;-) TP
