Hello Guest it is November 13, 2026, 09:50:49 AM
Author Topic: Mach3 Plasma G Code Loading Larger Than Table/Off Of Table  (Read 7222 times)
« on: June 15, 2020, 02:19:24 PM »
Hello,
I'm fairly new to Mach3 and am having some frustrations with my G Codes. I am able to load my DXF files through LazyCam to upload the G Code successfully into Mach3. However, the G Code presents itself off/beyond my table parameters. What should be a simple project presents as either much larger than my table dimensions or loads completely off of the table.  I am working with a 24 x 36 work space. Would someone be willing to assist me with troubleshooting?
Thank you in advance!
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach3 Plasma G Code Loading Larger Than Table/Off Of Table
« Reply #1 on: June 15, 2020, 02:50:54 PM »
I would guess the DXF files are in metric so your gode is 25.4 times size
