Hello Guest it is November 23, 2026, 05:06:50 AM
Author Topic: Having issue with y axis and a axis not moving together.  (Read 17965 times)
Offline dlang
  •  10 10
« on: June 14, 2020, 09:26:48 PM »
Hi
 Having issue when moving the y axis the A axis is moving at a different rate. On one end of the table the y and a axis are about 1/16 of an inch difference from side to side of table . Then on the other end the y axis and A axis are about 3/4 of an inch difference. Some how Im gaining steps .I switched stepper drivers and the same thing happens . Not sure what to look for . Is it possible that the stepper motor is bad . Can use any suggestion . Thanks Dan
« Last Edit: June 14, 2020, 09:28:40 PM by dlang »
  •  9,378 9,378
Re: Having issue with y axis and a axis not moving together.
« Reply #1 on: June 15, 2020, 12:00:17 AM »
Hi Dan,
Unlikely to be a bad stepper motor causing this behaviour. Check everything mechanical (loose set screws, tightness / binding on axis slides, etc) first.
Try reducing your velocity and acceleration settings in motor tuning by 50% saving the changes - does this make any difference to the error.
