Hello Guest it is November 13, 2026, 09:43:36 AM
Author Topic: Mach 3 backlash and circular interpolation  (Read 7482 times)
Offline Stev
  •  16 16
« on: June 13, 2020, 09:26:13 PM »
My holes are coming out oblong, backlash is set up correctly, and the only thing I can think of is try and reduce the backlash on the machine as opposed to just using the backlash compensation in Mach 3, but was wondering if there's anything else I could do?
Re: Mach 3 backlash and circular interpolation
« Reply #1 on: June 14, 2020, 04:20:53 AM »
backlash compensation is a myth. If you are trying to cut circular paths and your machine has
backlash the results are as you described. Fix the backlash.
