Hello Guest it is October 24, 2026, 05:28:58 PM
Author Topic: Mach4 soft limits reverse axes  (Read 8901 times)
« on: June 11, 2020, 01:16:01 PM »
I had this problem a long time ago and see posting from 2015, this issue has come up again but time I can not flip the values for min and max as the software gives an error message.
Everything is fine as long as Soft limits are disabled.
Mach 4 Version 4.2.3804
Windows 10 build 1709
Offline smurph
  •  1,575 1,575
Re: Mach4 soft limits reverse axes
« Reply #1 on: July 02, 2020, 09:46:57 PM »
This is because the soft limits are set incorrectly.  Min isn't always 0 and max isn't always positive.  It depends entirely on how the machine was built and what motion controller is used.
The soft limits are in machine native units.  To set them, home the machine first.  Then do one axis at a time.  This always uses the right hand rule.  She the Mill G code programming manual on page 6 for what the right hand rule is.
Run the axis towards the positive side until you hit the limit switch.  You should see the + limit light up on the diagnostic page.  Then back off a bit.  Then record this machine position for that axis.  It will go in the soft limit Max field.
Run the axis towards the negative side until you hit the limit switch.  You should see the - limit light up on the diagnostic page.  Then back off a bit.  Then record this machine position for that axis.  It will go in the soft limit Min field.
Steve
« Reply #2 on: December 09, 2020, 05:47:43 AM »
Hi Steve,
This is an awesome piece of information that I will have to take out into the shop and try out.
Is this in the Mach 4 manual? If not it should be.
Mike
Offline thosj
  •  542 542
« Reply #3 on: December 09, 2020, 11:45:44 AM »
Hi Steve,
Mike
Yeah, good info, but thinking about it, how else would you DO it? You need to find out where those limit switches are relative to where your home switch is. How, other than jogging over 'til you hit 'em, would you do it?
Tom
Tom
