Hello Guest it is November 25, 2026, 02:09:06 PM
Author Topic: Protect Mach3 Addons  (Read 112960 times)
« on: June 11, 2020, 12:49:39 PM »
I have been using the old Mach3 for years and have created some addons/wizard which I want to be run only on my machine.
The problem is that the code that the buttons run can be easily viewed by going to  >>>Operator>>>Edit button script  and then clicking the button.
Is there a way to protect my code from being stolen by others?
Offline TPS
  •  2,627 2,627
Re: Protect Mach3 Addons
« Reply #1 on: June 12, 2020, 05:35:36 AM »
you can save your code in different macros let's say M400.m1s then you open this macro with Operator -> VBScript Editor and do a save as and choose filetype compiled.
then you edit your Buttons and run only the macro   -> Code "M400".
then you can store your M1s files somewhere else and delete them from macro Folder.
