Hello Guest it is October 21, 2026, 01:06:26 PM
Author Topic: LMS 3990 Servo CNC Conversion w Servos  (Read 53696 times)
« on: June 09, 2020, 07:02:13 PM »
Wherein I document my attempts to convert a LMS 3990 to CNC using servos.
Re: LMS 3990 Servo CNC Conversion w Servos
« Reply #1 on: June 09, 2020, 07:02:44 PM »
« Reply #2 on: June 09, 2020, 07:03:19 PM »
« Reply #3 on: June 09, 2020, 07:03:47 PM »
LMS 3990 Servo CNC Conversion — Part 3: Creating the Missing ERR/RES Pin Wiring Circuit : https://medium.com/@john.obrien/lms-3990-servo-cnc-conversion-part-3-creating-the-missing-err-res-pin-wiring-circuit-bc4f4809317e
  •  9,374 9,374
« Reply #4 on: June 21, 2020, 01:58:50 AM »
Hi John,
You need to change your Medium privileges so that it is not a 'Members-only Account' or find another platform for publishing your conversion process.
To require readers / followers to sign-up for an account (free or not) is not acceptable.
« Last Edit: June 21, 2020, 02:14:02 AM by Tweakie.CNC »
« Reply #5 on: June 21, 2020, 08:44:19 AM »
Hi Tweakie.CNC,
Thank you for your feedback.
I have changed the Medium privileges so these articles are not 'Members-only Account'. Please let me know if you have any other questions, comments, or feedback.
Nice website BTW (http://www.tweakie.byethost10.com/). You've really laid out the information on your CNC conversion very clearly in a manner that is easy for other people to follow.
John O'Brien
« Reply #6 on: June 21, 2020, 08:45:41 AM »
LMS 3990 Servo CNC Conversion — Part 4: Installing the Heavy Metal CNC Conversion Kit: https://medium.com/garage-adventures/lms-3990-servo-cnc-conversion-part-4-installing-the-heavy-metal-cnc-conversion-kit-294ee6941a2e
  •  9,374 9,374
« Reply #7 on: June 22, 2020, 12:07:06 AM »
Hi John,
Thanks for changing the Medium privileges – now I can continue reading how you used an op-amp in the multi-axis servo fault detection.  :)
Also, thank you for sharing your experiences with us as I am sure they will help and inspire others who may be considering a servo CNC conversion.
