Hello Guest it is November 13, 2026, 09:59:50 AM
Author Topic: Probe debounce...  (Read 18866 times)
Offline Davek0974
  •  2,606 2,606
Probe debounce...
« on: June 06, 2020, 09:41:22 AM »
Hi all, been a few years since i was here :)
Needed to make a new surface probe for my plasma table, got the mechanics done but seen to have a little issue - if someone can confirm my diagnosis and then offer some help would one good :)
ISSUE:-
When running a Z axis probe, the switch will open and Mach3 wills sense the material but the axis does not appear to pull away from the material until the switch opens again.
DIAGNOSIS:-
Switch bounce - its closing and opening very rapidly i.e. bouncing and Mach3 senses it as having pulled away.
FIX:-
Adjust the debounce ion general config, trouble is there are two debounce settings - is this "Debounce" or "Index Debounce"
Thanks all
Re: Probe debounce...
« Reply #1 on: June 06, 2020, 08:51:31 PM »
A Mach3 probe does NOT automatically back away from the trip point . You have to program the macro to do so.
What does your Macro code look like ? IF you think Debonce will help then you use the Debounce setting.
Just a thought , (;-) TP
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: June 07, 2020, 12:31:48 AM »
It runs as a subroutine called from the main code before each plasma piercing.
Code: [Select]
G91 (switch to incremental mode)
G01 X24.00 Y2.00 F6000 (position probing point)
G90 (switch to absolute mode)
F2000
M1050 (trigger the probe cylinder)
G04 P0.3
G28.1 Z10.00 (probe the surface)
G92 Z#15045 (apply the probe switch offset from settings screen DRO)
M1051 (raise the probe)
G01 X-24.00 Y-2.00 F6000 (put the axes back to where we came from)
M99
I cant see why anything else would change - the subroutine has been running for a few years now, all i did was build a new mechanism and fit a new microswitch, tried two. It seems it sometimes backs away but not always??
The probe is offset from the torch so it needs the axes moving as in the sub.
Offline TPS
  •  2,627 2,627
« Reply #3 on: June 07, 2020, 02:33:04 AM »
your macrocode M1050 and M1051 would be interesting.
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: June 07, 2020, 02:36:28 AM »
M1050 =
ActivateSignal(OutPut3)
Sleep(300)
M1051 =
DeActivateSignal(OutPut3)
Sleep(400)
Offline TPS
  •  2,627 2,627
« Reply #5 on: June 07, 2020, 02:45:29 AM »
ok nothing Spezial there.
you are doing the probe with G28.1 (referencing) i see.
have you tryed a Ref Z in the diagostic page, witch should prizipial do the same Thing, just to verify.
before you start the probe/reference is the M3Home LED on diagnostic page on or off?
Offline Davek0974
  •  2,606 2,606
« Reply #6 on: June 07, 2020, 02:49:15 AM »
Not tried the ref z yet, will do that shortly.
The Home LED is off before the routine runs.
I'll be going out to play shortly, been a very long time since i touched this code, machine just runs and lately has been getting hammered hence the new probe build :)
Brings back lots of memories and headaches :) :)
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: June 07, 2020, 05:00:40 AM »
I think i have it now.
Probing speed was the issue - this particular microswitch does not like approaching trigger point slowly, after messing with debounce and macros i turned up the speed for the G28.1 setting in homing/limits.
It was on 20% now on 50% and accuracy seems to have returned, plus i get the added bonus of faster probing :)
I guess the switch internals are a little grey and not as good as the old one i took off.
After many dozens of runs and one test cut job i am satisfied that she'll be working ok Monday now.
Thanks for the tips guys.
Offline Davek0974
  •  2,606 2,606
« Reply #8 on: June 13, 2020, 08:44:25 AM »
Even better, fitted a longer air cylinder today, i can now get the probe tip way up out of the path of the plasma muck, I have also increased the speed to 100% rapid and accuracy is amazing - ran over 50 cycles with a DTI on the Z axis and it maintained +/- 0.05mm each time - plenty good enough for plasma work and very good for a common microswitch.
My earlier post was a little off  i am not probing - its using a ref-z instead and the ref process does need to back-off from the switch closure.
« Reply #9 on: June 14, 2020, 06:59:45 PM »
I remember back when you were working on it.
