Hello Guest it is November 16, 2026, 03:22:43 AM
Author Topic: Loop-d-loop G41  (Read 25477 times)
Loop-d-loop G41
« on: May 31, 2020, 12:12:10 AM »
Hi Guys
I seem to get this little extra loop cut that is not required
Pic attached of Screen shot
Also attached my G code file
Any Help appreciated
John Perkins
Re: Using G41 ..all good but for one spot
« Reply #1 on: May 31, 2020, 12:13:35 AM »
some how I did not attach the screen shot
JP
Loop-d-loop G41
« Reply #2 on: May 31, 2020, 04:30:10 AM »
I have the same issue and are yet to find the answer
I posted a very similar question before finding this thread
suppose i should use search first .....ooops
John P
« Last Edit: June 01, 2020, 09:51:28 AM by Tweakie.CNC »
  •  9,377 9,377
Re: Loop-d-loop G41
« Reply #3 on: May 31, 2020, 05:26:26 AM »
Hi guys,
This is really weird and something I have never come across before.
Which version of Mach3 are you using and which motion controller ?
Re: Loop-d-loop G41
« Reply #4 on: June 01, 2020, 05:55:03 AM »
Hi Tweakie
Thanks for closing other thread
I Have Current Version of Mach 3 and are using a UCCNC-   AXBB-E controller
John P
  •  9,377 9,377
Re: Loop-d-loop G41
« Reply #5 on: June 01, 2020, 06:59:04 AM »
Hi John,
In Mach3;  Help / About will show the Mach3 version number.  Which version are you using ?
Sorry but I was thinking of other things when I mentioned Motion Controller I should have said what CAD/CAM software are you using to generate the Gcode ?
Re: Loop-d-loop G41
« Reply #6 on: June 01, 2020, 07:16:52 AM »
Mach 3
I have  Version R3.043.062
I don't use cad/cam ...I write my own code ...then i can Understand the errors ..I often will run program with steppers off to see any errors or do a test run in MDF
I have added pic of machine
John P
  •  9,377 9,377
Re: Loop-d-loop G41
« Reply #7 on: June 01, 2020, 09:47:42 AM »
Hi John,
Very nice looking machine.
You are using the latest / best version of Mach3.
There is something not quite right dimensionally with your Gcode file but I am not clever enough to spot where the problem lies. I suspect that Mach3 thinks there is not enough room to apply the cutter radius compensation (lead-in) so it takes an alternative path.
Incidentally UCCNC also reports cutter radius compensation warnings when your Gcode file is loaded which may confirm a Gcode dimensional error is present.
Re: Loop-d-loop G41
« Reply #8 on: June 07, 2020, 03:10:00 PM »
Tweakie is correct. IF mach3 sees that the leadin is too short for teh tool it will create a path to make it work. Normally the path will be incorrect when it does so. One of Mach3 quirks.
I would not trust UCCNC error codes either as teh G41 in that controller has quirks of its own.
Just a thought , (;-) TP
