Hello Guest it is November 13, 2026, 10:41:20 AM
Author Topic: Homing double touch the home switch  (Read 14380 times)
« on: May 26, 2020, 10:38:13 PM »
So, I have been using mach3 for a LONNNGGGGG time.
Now I am trying to get the homing routine a little more accurate.
What I have now is I click home all or home+probe on my screenset
The button editor says DoButton (24)  DoButton (23) DoButton (22)
when I click home all it goes and touches the home switch, then reverses and stops.
What I would like to happen is it bounces off the switch, then move the axis 1mm away and repeats the process at 20mm per minute.
I cannot find the DoButton script.  Or How do I edit the button?
I appriciate the help, I do not know much about VB editing, but I am learning more and more.
Offline ZASto
  •  434 434
Re: Homing double touch the home switch
« Reply #1 on: May 27, 2020, 03:13:38 AM »
DoButton is not a script.
To edit button, go to: Operator -> Edit Button Script, then click on your REF ALL HOME button.
My personality is who I am.
« Reply #2 on: May 27, 2020, 09:54:04 AM »
This is what i get when I do that.
Offline ZASto
  •  434 434
« Reply #3 on: May 27, 2020, 12:35:33 PM »
And you an write code in the opened window.
DoButton (24) homes Z Axis,
DoButton (23) homes Y Axis,
DoButton (22) homes X Axis.
Try to find "Mach3 V3.x Programmer Reference Draft v0.11a.pdf"
It exists somewhere on this forum as an attachment.
  •  9,377 9,377
« Reply #4 on: May 28, 2020, 12:08:56 AM »
The 'Mach3 Programmers Reference Draft v0.11a.pdf' mentioned by ZASto can be downloaded from here; https://www.machsupport.com/forum/index.php?action=dlattach;topic=12740.0;attach=17815
« Reply #5 on: June 09, 2020, 12:25:50 PM »
I am still fighting this as I do not know VB at all.
I was able to edit my tool probe script by typing in simple G code commands but this is now working for me.
Can anybody dumb this down for me?
I have tried going to the button script editor and doing a
DoButton (24)
code(g91)
Code(g0z-1)
While Ismoving()
Wend
DoButton(23)
I did this just to see if I could get the Z to move down after the home.
But when I run it from the script editor window I get Compile error Script Error
« Reply #6 on: June 09, 2020, 01:18:47 PM »
Well I am gaining on this issue.  I am able to edit the button script for home all on my installed screenset.
I found a script on the forum that helped me, I edited all 3 axis calls  like this.  This is for the Z axis.
SetParam ("XRefPer",40)
DoOEMButton (1022)  'home at 40%
While IsMoving()
Wend
Code "G53 X-2"  'move off switch 2mm
While IsMoving()
Wend
SetParam ("XRefPer",5)
Sleep 200
DoOEMButton (1022)  'home at 5%
While IsMoving()
Wend
SetParam ("XRefPer",100)
End Sub
Now I do not know how to get into the screen set and edit the individual home buttons.  They do not flash when I go into Operator>Edit Button Scripts
  •  9,377 9,377
« Reply #7 on: June 10, 2020, 12:04:14 AM »
You need to use a Screen Designer (such as Klaus's Screen) https://www.machsupport.com/downloads-updates/screensets/
to change the buttons to VB buttons before you can enter your VB scripts.
