Hello Guest it is October 20, 2026, 05:07:20 PM
Author Topic: Constant velocity vs Exact stop  (Read 7015 times)
Offline PeteG
  •  33 33
« on: May 21, 2020, 12:55:37 PM »
So, I am once again confused. I have been running my machine in constant velocity mode, which seems to be the default. I had a little issue with corners rounding off and corrected this by altering the acceleration and deceleration settings.
Then I saw a YouTube vid which introduced me to the wonders of ‘exact stop’. This works well and creates really sharp corners but is a bit weird when cutting circles. So I tried the option to turn off CV on an angle greater than 89 degrees. I assumed that this would make the machine run in CV mode until it encountered a 90-degree corner and would switch to exact stop mode. But it doesn’t. No matter what angle is set, it stays in CV mode.
What am I doing wrong?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Constant velocity vs Exact stop
« Reply #1 on: May 24, 2020, 07:29:46 PM »
If its just an odd corner add a G61 before the corner and a G64 after the corner in the code or slow the feed down on the entry to the corner.
