Hello Guest it is November 22, 2026, 02:11:46 PM
Author Topic: Fusion 360 simultaneous machining on the A axis  (Read 51322 times)
Re: Fusion 360 simultaneous machining on the A axis
« Reply #20 on: June 11, 2020, 09:02:44 AM »
OK, I've seen that video - it was made when the rotary was just in Beta, so the setting up is different - and it had a lot of 'quirks' then, as mentioned in the video, and I also had a look at the 'toothpick' video mentioned. None of these provide any assistance with this issue, unfortunately, nor have several others I've looked at, hough none are very recent. It would be good if I could get a simple model sent that works for comparison, perhaps, or I can send mine somehow(?)
Offline HC
  •  13 13
« Reply #21 on: June 11, 2020, 09:18:53 AM »
now setup the wcs:  z up & x true the midpoint
« Reply #22 on: June 11, 2020, 09:44:39 AM »
OK, like the attached? Same issue.
Offline HC
  •  13 13
« Reply #23 on: June 11, 2020, 09:53:38 AM »
& it post  :)
« Last Edit: June 11, 2020, 09:55:31 AM by HC »
« Reply #24 on: June 11, 2020, 10:03:29 AM »
Really, did you not have to change anything? Can you send the GCode file for it!
« Reply #25 on: June 11, 2020, 10:27:00 AM »
Hmmm.... maybe I should reboot my PC... you never know. Seems others can get it running no problem.
Offline HC
  •  13 13
« Reply #26 on: June 11, 2020, 10:31:53 AM »
he he, forgot to save it first  :)
Offline HC
  •  13 13
« Reply #27 on: June 11, 2020, 10:42:40 AM »
in mach4
double check all  8)
« Reply #28 on: June 11, 2020, 10:49:21 AM »
Saved it here: https://a360.co/2AZvjHz
Rebooting didn't help, but I guess it must be something to do with my PC if you can produce a GCode (.tap, .nc?) file. Can you send me that? At least then I can machine it.
Barry
« Reply #29 on: June 11, 2020, 10:50:29 AM »
1:50 in the morning here, have to leave it for later...
