Hello Guest it is November 22, 2026, 02:11:48 PM
Author Topic: Fusion 360 simultaneous machining on the A axis  (Read 51323 times)
Re: Fusion 360 simultaneous machining on the A axis
« Reply #10 on: June 10, 2020, 09:18:37 PM »
I had high hopes, though there seemed to be no difference in the post Javascript, but no - same issue. Thought I would post some details here of the machine definition, in case that has something to do with it.  :(
And the error:
Information: Configuration: Mach4Mill
Information: Vendor: Artsoft
Information: Posting intermediate data to 'C:\Users\User\AppData\Local\Fusion 360 CAM\nc\1001.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Thursday, June 11, 2020 12:00:19 AM
Loading locale from 'c:\users\user\appdata\local\autodesk\webdeploy\production\1f559bb8ae333199306b5c4f1fe680c6eb7ab9e0\applications\cam360\data\posts\common.en.lang'
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5663.0
Configuration path: c:\users\user\appdata\local\autodesk\webdeploy\production\1f559bb8ae333199306b5c4f1fe680c6eb7ab9e0\applications\cam360\data\posts\mach4mill.cps
Include paths: c:\users\user\appdata\local\autodesk\webdeploy\production\1f559bb8ae333199306b5c4f1fe680c6eb7ab9e0\applications\cam360\data\posts
Configuration modification date: Wednesday, June 10, 2020 11:20:02 PM
Output path: C:\Users\User\AppData\Local\Fusion 360 CAM\nc\1001.nc
Checksum of intermediate NC data: 7720f01aa8be9125834a39cad2271931
Checksum of configuration: 31497b50757641ec0e0985e56b643eb4
Vendor url: http://www.machsupport.com
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.8412
Error: Error: Direction is not supported for machine configuration.
Error at line: 1
Stack dump:
("Direction is not supported for machine configuration.")@:0
onOpen()@c:\users\user\appdata\local\autodesk\webdeploy\production\1f559bb8ae333199306b5c4f1fe680c6eb7ab9e0\applications\cam360\data\posts\mach4mill.cps:220
Failed while processing onOpen().
Error: Failed to invoke function 'onOpen'.
Error: Failed to invoke 'onOpen' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thursday, June 11, 2020 12:00:19 AM
Post processing failed.
Offline Stuart
  •  311 311
« Reply #11 on: June 11, 2020, 01:45:34 AM »
Try deleting the machine config from the cam setup
I have had some funny errors using it for 3 axis work , it took a lot of thinking, changing Setting to get it to play nicely
It’s not really needed ,but nice to have when it works save any bo bo,s
« Reply #12 on: June 11, 2020, 03:05:27 AM »
Good idea, I'll try that.
« Reply #13 on: June 11, 2020, 05:39:31 AM »
No luck, unfortunately, though the error is different, I've seen it before while testing this 4th axis. It gets beyond the onOpen section, but baulks at a later point:
Information: Posting intermediate data to 'C:\Users\User\Documents\GCode\1001.tap'
Information: Total number of warnings: 1
Start time: Thursday, June 11, 2020 10:35:57 AM
Configuration path: c:\users\user\appdata\roaming\autodesk\fusion 360 cam\posts\mach4mill.cps
Include paths: c:\users\user\appdata\roaming\autodesk\fusion 360 cam\posts
Configuration modification date: Thursday, June 11, 2020 10:30:27 AM
Output path: C:\Users\User\Documents\GCode\1001.tap
Checksum of intermediate NC data: 07209c62a06e8359e0f5498d7bd47548
Checksum of configuration: cc39f4d79fa1ca1e66c5dc12919c75f4
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Error: Section.getInitialToolAxisABC() is not allowed for section.
Error at line: 1
Error in operation: 'Rotary1'
Stack dump:
("Section.getInitialToolAxisABC() is not allowed for section.")@:0
defineWorkPlane([object Section],true)@c:\users\user\appdata\roaming\autodesk\fusion 360 cam\posts\mach4mill.cps:390
onSection()@c:\users\user\appdata\roaming\autodesk\fusion 360 cam\posts\mach4mill.cps:895
Failed while processing onSection() for record 343.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Stop time: Thursday, June 11, 2020 10:35:58 AM
Offline Stuart
  •  311 311
« Reply #14 on: June 11, 2020, 06:10:23 AM »
Ok
I have just knocked up a test part
Like a pipe with a flange at each end and a flat lump on the side eg steam cylinder for a beam engine
Axis left end of bed along the x axis
Using that cps I posted it generated code correctly no errors
Z was modelled up from the centre of rotation with x poking out the centre in the normal direction for that axis
The WCS warning was it is looking for a 1 for g54 in the cam setup
So I am afraid you have me stumped, but I will keep my brain cell working ,it’s 73 years old now so a bit slow
Stay safe and well
« Last Edit: June 11, 2020, 06:26:57 AM by Stuart »
Offline HC
  •  13 13
« Reply #15 on: June 11, 2020, 06:38:49 AM »
it does work (pokey/mach4) with different post"s
Guess the wcs is setup wrong
Offline HC
  •  13 13
« Reply #16 on: June 11, 2020, 06:48:46 AM »
double check my setup, mmm   rotary axis setup X
                                               origin setup wcs  but it shows the opposite  :)
maybe share your setup
« Reply #17 on: June 11, 2020, 07:41:54 AM »
Hi, tried setting to mill and turn, but same error. Attached is the setup; maybe something is not right here...
Offline HC
  •  13 13
« Reply #18 on: June 11, 2020, 08:17:49 AM »
ok, this ain't going to work.  :)   you have to turn the piece 90°  aligned to X
look some ytube video how to setup
https://www.youtube.com/watch?v=IPi48a-y0VQ&t=503s
don't select a machine & operating typ: milling   just to get going
« Reply #19 on: June 11, 2020, 08:58:33 AM »
I'll check that one out, but turning it made no difference...
