Hello Guest it is November 22, 2026, 07:29:52 AM
Author Topic: Set for mm but moving in inches.  (Read 20094 times)
Offline PeteG
  •  33 33
Re: Set for mm but moving in inches.
« Reply #10 on: May 16, 2020, 10:49:25 AM »
Your advice was spot on, thanks. I've just used the axis calibration tool, and run a test of X at 150mm & Y at 100mm, Y is exactly 100mm, but X is coming out 150.03mm so I think there maybe some errors creeping in somewhere.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #11 on: May 16, 2020, 11:23:37 AM »
What figures are in the steps per for each axis now?
Offline PeteG
  •  33 33
« Reply #12 on: May 16, 2020, 12:43:29 PM »
Around 200 plus a load of numbers after the decimal point. I had to massively increase the feed rate and accel/decel and it's all working very smoothly and acceptably.
I used a dial gauge to set the steps, but X wasn't coming out right as I was only able to check travel over 20mm. Y was spot on, maybe because there are two motors driving it - maybe, maybe not. So I rigged up a jig to hold a vernier gauge and was able to set X over a distance of 100mm and it is now super accurate.
