Hello Guest it is October 10, 2026, 08:46:14 AM
Author Topic: Recommend me a high quality MPG Wheel?  (Read 5918 times)
Offline SimonRafferty
  •  46 46
  • Movie SFX Design Engineer
« on: May 07, 2020, 04:17:43 AM »
I've bought a couple of MPG Wheels & encoders over the years, but none of them had the same, nice, feel as Fanuc or Heidenhain wheels.
What makes a good one?  Enough mass that when you spin it, it will keep going for a turn or so, with enough damping that it will stop.  Soft detents so you can feel each click, but they don't interfere with spinning.  Nice finish.  It probably doesn't need a scale on it - as it changes with the jog increment.
I don't need a complete pendant - i'm going to build that!
My plan for the pendant, inspired by this post on Instructables:
https://www.instructables.com/id/Mach4-Pendant/
I'm not keen on the touch screen - I'd like buttons I can feel & operate without looking at them!
My plan (which may or may not work!) is to use the Lua Serial plugin to talk through a wireless USB Extender, to an Arduino on board the pendant.
I'll write a PLC script which will establish 2 way comms with the pendant - sending axis positions and reading the MPG & buttons.  If that doesn't work, an arduino at both ends with X-Bee comms and feed the MPG + Buttons into the BoB as if it were connected directly.
I'm not keen on the keystroke injection method most seem to use - it's dirty!
First step though is a nice MPG Wheel!
Thanks in advance,
Si
Re: Recommend me a high quality MPG Wheel?
« Reply #1 on: May 07, 2020, 06:09:06 AM »
I use a VistaCNC P1A pendant...it has its own USB plugin and works well. I didn't have to shag around making
my own.
Whether it could be said to have as nice an MPG as you describe....I don't know, I certainly like it.
  •  46 46
« Reply #2 on: May 07, 2020, 06:20:15 AM »
Thanks Craig.  The Vista Pendants seem to be the only off the shelf option for Mach4 at the moment.
I could just buy one - but I enjoy building my own solutions.  It may not end up being as good - but it's mine!
That said, the ones I've made in the past have been pretty good - so, if I can make a nice one and publish the design + scripts then it opens up another possibility for people who want to build their own.  At the very least, it gives me a useful project during the Lockdown!
