Hello Guest it is October 11, 2026, 06:14:50 AM
Author Topic: Mach 4 open source content  (Read 8797 times)
« on: May 04, 2020, 11:33:40 PM »
There were various open source screens and other forms of useful and innovative content for Mach 3, does anything like that exist for Mach 4? I remember, for example, a probing code snippet/routine for edge finding in Mach 3 by a user named Squirrel on another forum. Thanks for your help!
Re: Mach 4 open source content
« Reply #1 on: May 05, 2020, 01:17:12 AM »
download Mach4 and find that there are a large number of macros and complete modules that are source files
and intended that they be used, either as excerpts or complete, by users for their own purposes.
« Reply #2 on: May 05, 2020, 09:13:56 AM »
I don't know of many screen sets floating about, but there are lots of scripting examples and information installed by Mach4 in the folder:
/Mach4Hobby/LuaExamples
Steve Stallings
www.PMDX.com
« Reply #3 on: May 13, 2020, 02:56:00 AM »
Also have a look at the wizards. I did the bolt hole wizard in a way to show how you can make a wizard with limited programming knowledge. It looks a bit nasty at first but you will see that it will automatically make the dialog layout for you.  If you follow that example it can be pasted into a Lua panel in the screen designer as well. It could be used to make a nice probe wizard or other control. If you want to be overwhelmed with code have a look at all the font engraving code. This is all on the modules addons directory. It is really cool but it gets deep fast.
www.newfangledsolutions.com
www.machsupport.com
« Reply #4 on: May 13, 2020, 10:08:42 AM »
A short video using wxFormBuilder to create a form/listbox/... and then showing how to insert that into a panel would go a long way to help us understand how to use lua in panels.  I sent Bryanna an email about a year ago suggesting this.
RT
« Reply #5 on: May 13, 2020, 10:21:45 AM »
I will have the guys make one :)
www.machsupport.com
