Hello Guest it is September 15, 2026, 07:28:52 PM
Author Topic: Feed Rate FRO% control with potentiometer pedal PLEASE ADVISE  (Read 8761 times)
Hi Folks,
This is my third Mach3 machine build but I need a slightly out of the ordinary solution.
I want to build a little 2 axis turning machine for wrapping wire on a mandrel at a varied pitch.
I would like to control the feed rate (via FRO%) using a foot pedal.  I found a sewing machine pedal that is a simple potentiometer that uses a 3.5mm headphone jack (max 15V) that I want to use. I suppose could read the voltage via arduino if necessary but then what?
Can anyone suggest the best method for this? For instance is there a analog read capability built in to a basic BOB?
I want the pedal to go from 0% FRO with no foot and 250% pedal to the metal.
Any help greatly appreciated!!!!
Offline ZASto
  •  434 434
Re: Feed Rate FRO% control with potentiometer pedal PLEASE ADVISE
« Reply #1 on: May 01, 2020, 03:38:56 AM »
just do a google search on "mach3 arduino modbus"
My personality is who I am.
« Reply #2 on: May 01, 2020, 05:31:01 AM »
the Pokeys 57CNC and the UC300 both have analogue inputs.
Craig.
« Reply #3 on: May 01, 2020, 01:25:56 PM »
Great! Thank you so much for the spot-on replies.  I saw the UC300 and thought it looked promising.
Can anyone outline how the analog input maps to the feed rate?
I want to use the analog input signal as a set-point, i.e. voltage mapped to a given FRO%.
Are "Brains" and Modbus understandings both necessary components to executing?
Can anyone give me a basic roadmap of what I need to set to learning?
Thank you.
