Hello Guest it is October 05, 2026, 02:18:12 PM
Author Topic: Sorry to ask, but ... LIMIT SWITCHES  (Read 7647 times)
« on: April 30, 2020, 11:57:49 AM »
I hate to ask a really ROOKIE question, but ...
Are limit switches strickly a break in CONTINUITY, or do you need to supply voltage?
Had a problem testing the Estop. Can't seem to get it to work using a break in continuity only.  I understand N/C vs. N/O.  I have tried GROUND to ESTOP connection using only a break in continuity. Getting a direct answer to the question above has been difficult.  (Broke a coupler because it wasn't working).
I am using a SainSmart 5 Axis BOB.
Thanks in advance.
Bob
« Last Edit: April 30, 2020, 12:09:50 PM by rfhall50 »
Re: Sorry to ask, but ... LIMIT SWITCHES
« Reply #1 on: April 30, 2020, 03:52:51 PM »
No, they are not strictly NC, although it is common.
On the Config/Ports&Pins/InputSignals page you enable each of the limit switches and also nominate whether the signal
is active high or active low.
It was very common to use six snap action microswitches NC contacts and all wired in series. Therefore any wire break (fault) or any
switch activation (to open circuit, ie limit event) would cause a limit event and the machine would Estop.
« Reply #2 on: April 30, 2020, 08:16:44 PM »
Thank you for your quick response.  Based on what you told me, plus a graphic I found, I think I need to recheck my setup.  Thanks again.
Bobby
