Hello Guest it is November 13, 2026, 10:03:38 PM
Author Topic: infrared screen  (Read 18252 times)
infrared screen
« on: April 30, 2020, 09:15:07 AM »
I want to make a makro for a infrared screen.
Only while running a G-code and there is an input from the infrared screen .
The machine will go in reset or stop state.
Where do I have to start?
Re: infrared screen
« Reply #1 on: May 02, 2020, 04:31:11 AM »
I have now this:
   Sub Main
      If  GetOEMLED(1000) Then ' is run
      If IsActive(INPUT1)And (GetLed(116) = true) Then
      DoOemButton(1004)      ' 1004 DoOemButton stop
      End If
      End If
   End Sub
It is not working, any idea?
Offline TPS
  •  2,627 2,627
Re: infrared screen
« Reply #2 on: May 03, 2020, 03:05:26 AM »
try this
Code: [Select]
   Sub Main()
      If  GetOEMLED(804) Then ' is run
        End If
      End If
   End Sub
