Hello Guest it is November 10, 2026, 01:53:26 AM
Author Topic: yet another lathe turret macro needing assitance  (Read 18500 times)
« on: April 29, 2020, 04:50:05 PM »
So I'm pretty handy in the fabrication side of things, but when it comes to coding i'm just terrible. I'm making a ratcheting style turret for my lathe and I think i've gotten a good start on the M6 marco, but I get a compile error any time I try to run it. Can someone more versed in VB please take a look at it and see what I'm doing incorrectly?
Dim Num_Tools As Integer
Dim Ang_Move As Integer
Dim Req_Tool As Integer
Dim Current_Tool As Integer
Dim Lock_Move As Integer
Dim CW_Feed As Integer
Dim CCW_Feed As Integer
Dim Moves As Integer
Num_Tools = 12 'number of tools on turret
Ang_Move = 360/Num_Tools 'angular rotation per tool
Req_Tool = GetSelectedTool()
Current_Tool = GetCurrentTool()
Lock_Move=15 'distance to move back onto paw to lock
CW_Feed=100
CCW_Feed=50
'Start tool change
If Req_Tool < 1 Then
Message"Tool number too low"
Code "M30"
End If
If Req_Tool = Current_Tool Then
'do nothing
Else
'do tool change
If Req_Tool > Current_Tool Then Moves = (Req_Tool - Current_Tool) * Ang_Move
Else
If Req_Tool < Current_Tool Then Moves = (Num_Tools - Current_Tool + Req_Tool) * Ang_Move
End If
'move to safe position
Code "G0 G53 X-.25 Z-.25"
Code "G04 P0.5"
'index turret
Code "G91 G94"
Code "G01 A" & Moves + 10 & "F" & CW_Feed
Code "G01 A-" & Lock_Move & "F" & CCW_Feed
While IsMoving()
Sleep(10)
Wend
SetCurrentTool Req_Tool
SetUserDRO 1500 , Req_tool
Code "G90"
Code "F" & Current_Feed
Offline TPS
  •  2,627 2,627
Re: yet another lathe turret macro needing assitance
« Reply #1 on: April 30, 2020, 01:17:33 AM »
Code: [Select]
Lock_Move    = 15 'distance to move back onto paw to lock
CW_Feed      = 100
CCW_Feed     = 50
'Start tool change
  Code "M30"
End If
  'do nothing
Else
  'do tool change
  End If
  End If
End If
Code "G04 P0.5"
'index turret
Code "G91 G94"
While IsMoving()
Sleep(10)
Wend
Code "G90"
« Reply #2 on: May 01, 2020, 05:41:56 PM »
you sir are a gentle man and a scholar. Thank you very much!!
