Hello Guest it is October 22, 2026, 08:40:10 PM
Author Topic: Mach4 Minor Stops after each GCode Line  (Read 6707 times)
« on: April 25, 2020, 04:14:56 AM »
My Machine does a minor stop (propably about a few ms) after each Line of GCode. I can not see it in the moves the machine does but you can hear, that the stepper motors stop moving for a moment. I use Mach 4.2.0.4466 with ESS in my machine. My machine did not show that behaviour with Mach3.
Does anyone have an idea how to get rid of that?
Marius
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach4 Minor Stops after each GCode Line
« Reply #1 on: April 25, 2020, 06:32:44 AM »
Is CV turned off
« Reply #2 on: April 26, 2020, 04:29:40 AM »
Yes, the machine is set to exact stop
  •  2,785 2,785
« Reply #3 on: April 26, 2020, 05:48:40 PM »
That is why its pausing, set it to CV on G64 or click the button on screen and remove any G61 from your code.
« Reply #4 on: April 27, 2020, 10:42:46 AM »
That solved my Problem!  :)
Thank you so much!
