Hello Guest it is November 26, 2026, 02:22:06 AM
Author Topic: Tool Number read from Mach's Tool Table?  (Read 97435 times)
« on: September 22, 2007, 03:26:07 PM »
Can the program be written to get my tool diameter automatically from the entries in my Tool Table Data when I type in a tool # in the NFW screen?
Pat
Re: Tool Number read from Mach's Tool Table?
« Reply #1 on: September 24, 2007, 09:07:42 PM »
Ron,
Is this included in the next upgrade or is it not doable?
Pat
« Reply #2 on: September 28, 2007, 08:10:47 PM »
I do not think the tool table data is accessible to VB. There was some recent discussion on this, but I dont hink it will be possible.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: September 30, 2007, 04:33:55 AM »
You can get the data like this :-
GetToolParam(SHORT toolnum, SHORT param) for tool parameters. Param numbers are 1 - n and correspond to the tool window in the mill or turn modes.
In turn for example, 1 is TipDia, 2 is Tip Radius..ect..
Graham.
« Reply #4 on: September 30, 2007, 10:32:27 AM »
Graham,
Thanks.  It is exactly what I was hoping existed to get the tool info.
What is the best source for the complete list of VB functions?
Pat
« Reply #5 on: September 30, 2007, 07:46:08 PM »
You got to watch Graham, he's pretty bad about pulling a rabbit out of the hat.  :)
« Reply #6 on: September 30, 2007, 10:28:49 PM »
Graham,
Any way to get the "tool description" from the tool table in addition to the tool diameter and offset length?
Pat
  •  2,785 2,785
« Reply #7 on: October 01, 2007, 03:57:33 AM »
I have not found one for doing that.
Graham.
vmax549
« Reply #8 on: October 01, 2007, 11:33:35 AM »
YOu can bring in the current tool # info by setting up a text Label using "TOOLDESC", it will retreive the currently loaded tool # description . I use it in an AUTO tool setting page. You would just need to setup the macro to load up the tool# you need the references on first then extrat the info.
You can also use the Get/Set Tool Param calls to modify the tool data. BUT you cannot change the tool description except in the tool Table Config.
« Reply #9 on: October 01, 2007, 11:33:19 PM »
Thanks, it works as advertized.  Where do you find this information in the documantation?
Also is there a way to read the label text from the TOOLDESC label in VB code after it displays the tool description?
Pat
