Hello Guest it is November 22, 2026, 07:10:38 PM
Author Topic: Upgrade from Mach3 to Mach 4 with Huanyang HY series VFD  (Read 9537 times)
« on: April 20, 2020, 08:09:33 PM »
I have been searching for a while for a clear resolution to this problem so i am hopeful that someone here can point me in the right direction.  I have an HY series Huanyang VFD and spindle that is working quite well under Mach3 using a RS-485 and the Huanyang plugin.  I am wanting to move to Mach4 and am running into issues with trying to figure out what I need to make this VFD work with Mach4, or if I am going to have to upgrade this thing.  As I understand it, the HY version does not implement adhere to the modbus standard and this is why a special plugin is required.  I have tried to configure using the Mach4 ModBus plugin and Bill Caldwell's write up on 'Connecting a VFD to Mach4 through Modbus (RS485)' with no success.  If there are devices out there that convert PWM to whatever the HY series is accepting, I am not able to identify anything.  I use the Ethernet Smoothstepper as my controller if that helps at all.  If I must upgrade in the end, what are some recommendations this group may have on what would be a good option to purchase?
Any help you all can be would be greatly appreciated!  Thanks.
Re: Upgrade from Mach3 to Mach 4 with Huanyang HY series VFD
« Reply #1 on: April 20, 2020, 09:03:18 PM »
my understanding is that a specialist plugin is required for Modbus to work with the HY series VFDs by virtue
of the Huanyang not complying with the Modbus standard.
There is a plugin for the HY in Mach3 but I do not for sure know whether there is a similar Mach4 plugin.
Apparently Huanyang must have gotten a lot of bad publicity over their non-compliance with their HY series
so they have released a new model that does called the GT series.
Another cost effective brand of good quality and support is Delta, Taiwanese manufactured in China. They have
quite a range.
Craig.
« Reply #2 on: April 20, 2020, 09:05:44 PM »
of course I ommitted to ask why that you wish to control it with Modbus, is not PWM good enough?
Certainly the ESS is PWM capable and depending on your BoB you should have analogue 0-10VDC
for a VFD, why not yours?
« Reply #3 on: April 20, 2020, 09:15:56 PM »
Hi Craid, thanks for you quick response.
I would think PWM would be good enough, but to be honest, I have not found enough quality guidance on how to properly configure this with the VFD.  My HY manual does not even reference PWM although it does reference SPWM but I understood that this is what it is doing through the RS485.  I admit that I could be missing something in my understanding though.
Are you aware of any good info or instruction on how to make an HY work properly using PWM and an ESS?  Or what I may be missing?  I would really like to avoid buying a whole new VFD if possible.
« Reply #4 on: April 20, 2020, 10:03:46 PM »
the first instance you will need to establish whether you BoB has an analogue ouput.
What is your Bob?
Offline thosj
  •  542 542
« Reply #5 on: April 21, 2020, 08:14:45 AM »
I would think PWM would be good enough, but to be honest, I have not found enough quality guidance on how to properly configure this with the VFD.  My HY manual does not even reference PWM..........
Does your VFD manual mention control via 0-10v? The VFD isn't "controlled" by PWM, PWM on the BOB controls 0-10v output which, in turn, controls the VFD.
Tom
Tom
« Reply #6 on: April 22, 2020, 08:39:28 PM »
I think you guys have identified part of what I have been missing.  I do not know if my BOB does 0-10v output for PWM.  I don't have any instruction for it so may need to plan on buying one that does.  The VFD manual does reference the 0-10v control so will likely do it if I had a BOB that was capable.  I was confused why my laser works fine on PWM, but as I have looked into it more the laser only needs 0-5v to work.  Now I see why the spindle PWM is different.
Will keep you posted after I get a new BOB.
