Hello Guest it is October 22, 2026, 07:42:22 PM
Author Topic: Trying Mach 4 for the first time, Gcode won't load, fine in Mach 3  (Read 8683 times)
Offline Zaae
  •  120 120
Hi all,
I've been using Mach 3 for a long time, got the bug today to look into how far development for Mach 4 has come. I downloaded the demo version today.
I wrote a program years back that sorts and separates tools from multiple programs, then compiles all the gcode back into a single file, with a probing routine and math to adjust the Z for uneven materials. I've used my custom software for years, it works very well with Mach 3, but Mach 4 gets stuck at "Tool path progress" while opening the gcode file. I don't get any errors, it just hangs. If I push cancel during loading, the gcode is all in the window, but there's no preview, and I can't run the code.
I tried poking at it a bit, but haven't found what's causing it yet, so I thought I'd ask here.
Here's a sample code, with just a single program with probing.
https://pastebin.com/Xx7P0bge
Z
Offline Zaae
  •  120 120
Re: Trying Mach 4 for the first time, Gcode won't load, fine in Mach 3
« Reply #1 on: April 16, 2020, 06:00:09 PM »
EDIT:
Wrong pastebin link, that was one I was fiddling with trying to find the problem. Here's a complete file:
https://pastebin.com/BXg5Ua6x
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: April 16, 2020, 06:50:02 PM »
Mach4 has a default tool/offset limit of 16 if you go in to Config you can set it higher OR make your tool numbers 4 and 5 and thin it will load.
Offline Zaae
  •  120 120
« Reply #3 on: April 16, 2020, 07:03:30 PM »
Hi Graham,
Thanks for your reply! I see it loaded for you, but I tried setting the tool numbers to 4 and 5, and it still hangs for me. I also checked the tool config area, and this is how it was set by default:
I must be missing something more.
Z
  •  2,785 2,785
« Reply #4 on: April 16, 2020, 07:54:52 PM »
Have you got mach4 enabled ? flashing button
« Reply #5 on: April 17, 2020, 01:30:31 AM »
If you are using build 4300 I believe there is a bug with ‘M0’ which causes Mach to lockup when loading g-code as you described. You can try a newer build from the ftp site
Offline Zaae
  •  120 120
« Reply #6 on: April 17, 2020, 11:39:45 AM »
Thanks SwiftyJ, that was the trick. I appreciate the help from you both.  :)
