Hello Guest it is October 25, 2026, 08:34:23 AM
Author Topic: Frustrated Newbie,  (Read 19809 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Frustrated Newbie,
« Reply #10 on: April 16, 2020, 08:10:02 PM »
Do not use any software that came with the package, its pirated and we know it and strange things happen when you run it.  Download from the downloads page and run it in demo mode until you are happy.  If you have a genuine licence use it.  Do NOT use any provided by the hardware supplier.
« Reply #11 on: April 16, 2020, 08:12:19 PM »
Will do, ill delete the current one and down load off the site
Thank you
« Reply #12 on: April 18, 2020, 05:35:06 AM »
Hi Mate,
oK a little progress, i reloaded the software from Artsoft.
Went through the settings and no still no go.
You mentioned the enable thing so i removed that wire from one of M335 drivers and i noticed the power supply fan stepped up likes its been unloaded.
Nothing happened, until i took the enable wire off the other two drivers and now i have 2 axis moving but regardless of +/- jolt they go the same direction.
At a guess one of the drivers is bad maybe which i have a spare, if that works why would the axis only go one direction?
Appreciate your help
  •  2,785 2,785
« Reply #13 on: April 18, 2020, 05:32:59 PM »
Bad wiring is my guess or the direction pin is set wrong.
« Reply #14 on: April 18, 2020, 09:08:16 PM »
Ok sorted and running, seems the driver was dead
Fitted another but same wiring and we are in business, thank you for your time
