Hello Guest it is October 22, 2026, 05:54:55 PM
Author Topic: Passing variable for gcode to module  (Read 5880 times)
Offline DAAD
  •  105 105
« on: April 13, 2020, 09:16:25 AM »
At the moment i'm making a button to execute a function from in the module i have made.
but at the moment i'm stuck on howto pass the gcode placed into the button into the module function.
Here is what i did:
Button code:
Code: [Select]
mc.mcGetInstance()
local gcode = "G00 G90 G53 G0 Z-20 A-20\n G90 X0 Y0 \n"
package.path = wx.wxGetCwd() .. "\\Modules\\AvidCNC\\?.lua"
zc = require "MyzControl"
zc.CallGcode(gcode)
zc.CheckRouter() --functie in module MyzControl
Module function:
Code: [Select]
function zControl.CallGcode(gcode)
local rc = mc.mcCntlGcodeExecute (inst,gcode)
if rc~=0 then
mc.mcCntlEnable(inst, false)
mc.mcCntlSetLastError (inst, "Something whent wrong when executing gcode / machine disabled for safety. error state "..rc)
end
Other module functions called from the button are working fine indicating that the problem lies within the formulation of the gcode/passing.
Offline Bill_O
  •  615 615
Re: Passing variable for gcode to module
« Reply #1 on: April 13, 2020, 09:56:12 AM »
I found that for me Registers are very useful.
•   How to turn on Registers.
Go to Configure, Control, Plugins tab then place a green check next to Regfile.
•   How to make a new Register.
Go to Configure, Plugins then Regfile.
Click on the green plus sign.
   Give the register a name. (no spaces)
   Give the register a starting value.
   Put in a longer description.
   Persistant
      A green check will keep value on exit from Mach4.
      A red x will start every new start of Mach4 with the starting value.
•   How to read a Register.
local variable = mc.mcRegGetHandle(inst, ‘path’)
local variable2 = mc.mcRegGetValue(variable)
   Examples:
local hreg = mc.mcRegGetHandle(inst, ‘Encoder_0’)
local EncRawVal = mc.mcRegGetValue(hreg)
or
local hreg = mc.mcRegGetHandle(inst, ‘ESS/EncRaw’)
or
local hreg = mc.mcRegGetHandle(inst, ‘iRegs0/NotchTime’)
•   How to write to a Register. (this might be wrong)
local mc.mcRegSetValue(variable, value)
or
local mc.mcRegSetValue(variable, tostring(value))
   Example:
local mc.mcRegSetValue(hreg, 23.35)
   or
local Num = 23.35
local mc.mcRegSetValue(hreg, tostring(Num))
Offline DAAD
  •  105 105
« Reply #2 on: April 13, 2020, 12:59:32 PM »
thanks for the reply
Think i will just put in the gcode directly.
Tought it was something simple i had overseen.
Adam
