Hello Guest it is November 13, 2026, 07:59:37 PM
Author Topic: Collision detection on THC  (Read 9010 times)
« on: April 11, 2020, 04:26:08 AM »
Hello
Hope someone can point me in the right direction.
I have a Price Cnc THC and I would like to add collision detection when the digitize input is activated.
I'm not sure of the best route to take.
Offline TPS
  •  2,627 2,627
Re: Collision detection on THC
« Reply #1 on: April 11, 2020, 05:30:34 AM »
you can do it via macropump macro.
you have to add some code in your digitze macro as well:
Code: [Select]
'put this as the first line in your digitize macro
SetOEMLED(1400,1) 'tell macropum it it a real digitze
'put this as the last line in your digitize macro
SetOEMLED(1400,0) 'tell macropum it it a real digitze is done
the the code for macropump
Code: [Select]
If ((GetOEMLED(1400) = False) and (GetOEMLed(825) = True)) Then
   MSGBox ("Probe hit during cut")
   DoOEMButton(1003) 'Stop machine
End If
something like this should work, code not tested, just written down
« Reply #2 on: April 14, 2020, 01:39:44 AM »
Thanks, I haven't done any coding in my files, but I should be able to find my way through it.
« Reply #3 on: April 14, 2020, 04:28:08 AM »
Could you tell me how to find these files?
Offline TPS
  •  2,627 2,627
« Reply #4 on: April 14, 2020, 11:10:23 AM »
there should be a Folder c:\mach3\macros\your Profile Name.
there should be all your macro files, i think your probing will be in M3.m1s
